Use this procedure to:
  • display the configured key details for given key name.
  • display the digital certificate for the given certificate index or list all the certificate details from the local store if the certificate index is not specified.
  • display the CA details for given trustpoint CA name or list all the CA details from the local store if the CA name is not specified.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select Certificate.
  3. Select the Certificate tab.
Certificate Field Descriptions
Use the data in the following table to use the Certificate tab.
Name
Description
Type
Specifies the certificate type.
VersionNumber
Specifies the version number of the certificate for the subject as issued by the Certificate Authority.
SerialNumber
Specifies the serial number of the certificate for the subject as issued by the Certificate Authority.
IssuerName
Specifies the name of the issuer of the certificate for the subject as issued by the Certificate Authority.
ValidStartPeriod
Specifies the start date of the validation period of the certificate for the subject as issued by the Certificate Authority.
ValidEndPeriod
Specifies the last date of the validation period of the certificate for the subject as issued by the Certificate Authority.
CertificateSignatureAlgorithm
Specifies the algorithm used for the signature of the issuer on the certificate for the subject as issued by the Certificate Authority.
Specifies the signature of the issuer on the certificate for the subject as issued by the Certificate Authority.
Subject
Specifies the details of the subject on its certificate as issued by Certificate Authority.
SubjectPublicKeyAlgorithm
Specifies the algorithm used to generate the public key of the subject for the certificate issued by the Certificate Authority.
SubjectPublicKey
Specifies the public key of the subject used for the Certificate Signing Request.
HasBasicConstraint
Specifies whether the certificate contains any basic certificate constraint or not.
HasKeyUsage
Specifies whether the certificate contains basic key usage constraint or not.
IsCa
Specifies whether the certificate is a ca certificate or not.
KeyUsage
Specifies the purpose of the key used in the certificate. It is represented in the form of bits as follows:
  • bit 0 - digitalSignature
  • bit 1 - nonRepudiation
  • bit 2 - keyEncipherment
  • bit 3 - dataEncipherment
  • bit 4 - keyAgreement
  • bit 5 - keyCertSign
  • bit 6 - cRLSign
  • bit 7 - encipherOnly
  • bit 8 - decipherOnly
Status
Specifies the status of the certificate.
Installed
Specifies whether the certificate is installed or not.
CdpUrl
Specifies the CDP URL present in the Digital Certificate Extensions field.
OcspUrl
Specifies the OCSP URL present in the Digital Certificate AIA field.
ExtendedKeyUsage
Indicates the purpose for which the key is used in addition to or in place of the basic purposes indicated in the key-usage field of the certificate.
RevocationStatus
Specifies the revocation status of the certificate.
